So, I've been having a long battle with the Pathfinder...here is the summary:
The problem first occurred when I would lose power at 3k RPM (stalling..sputtering) and was throwing a code for the VVT solenoid on bank 2.
Was fine for about 50 miles and started doing the same and eventually got worse. I made it to a shop and it died in the parking lot and would not start.
The mechanic asked when I had changed the oil last and I told them I had changed it the week prior when I swapped out the VVT solenoid. They flushed it and changed the oil and it seemed to
be running better than ever. I got about an hour from the shop and it started doing the same thing and barely made it home. The car again would not start.
It then started throwing a P0340 and I replaced the Camshaft pos sensor. It would barely start/stay running and eventually did not start.
I then cleaned the wiring connect and manually set TDC and finally got it running but is back to not having acceleration and stalling around 3k.
Also, it is now throw P0011, P0021 for both banks and P0340 for the bank 1 in which I just replaced.
Any ideas?
Again, Bank 1 Cam Pos Sensor is new and VVT solenoid on bank 2 is new.
Thanks for any advice or tips!
