I recently had a P1140 on both banks, I replaced the sensors and reset the code. But, ever since I am seeing an issue.
Ideally, When you are 4th gear and you go up to 3rd and press on the throttle - the rpm goes up and the car jets forward. But, what I am seeing now is the rpm does go up but the car is lagging on the forward movement you would expect for that rpm.
Please advise.
