Patching Drywall?
Home project-related forums. Woodworking, home improvement, landscape, and cooking discussion forum. Yeah, car guys cook.
240marcuSX
Car: E34 525i
E46 M3
Anybody know how to do this? Im watching tutorials on it right now, doesnt seem too bad.
I have a couple holes in my bedroom walls from when I got pissed off as a kid, and now its time to fix them.
One of them I think is small enough to put some mesh over and sand smooth, but the other I think needs to be cut out and patched.
Ive been watching this: http://www.easy2diy.com/cm/eas...#shop
Any other advice?
240marcuSX
Car: E34 525i
E46 M3
ok well. I just got back from the hardware store, I bought everything I needed for about $38, I'll let you know how everything goes, if anyone cares.
Papi Chulo
Car: 72' Datsun 510
That link is how I do it, minus the wood strips.
240marcuSX
Car: E34 525i
E46 M3
So you just use the mesh tape? or do you attach the new drywall to the existing studs? I have a large hole, over 3" in diameter.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
post pics of the holes, and if possible, show where the next studs are on either side of the holes.
Papi Chulo
Car: 72' Datsun 510
240marcuSX wrote:So you just use the mesh tape? or do you attach the new drywall to the existing studs? I have a large hole, over 3" in diameter.
I use paper tape but mesh works just the same. You're not just covering the hole with tape and applying compound, that will leave it uneven and it will eventually crack.
If there's a stud in the area then yes, if not use the wood strip method. I just cut the square to fit tight, tape it with compound, sand, then texture.
240marcuSX
Car: E34 525i
E46 M3
OK, I just cut out an 8"x12" hole, and cut a piece of drywall to fit. It doesnt fit tightly enough to not use the board, so I will have to use it. I cut out such a big piece because the damage was much bigger on the other side of the wall.
There is one stud about a centimeter away on one side, but on the other side there isnt one anywhere near. If the hole were more directly over the stud I would just use the stud.
My main concern is making it look even, because this is a little bit of a covert operation.
Q451990
As a real estate investor, I have patched waaaaay too many holes in drywall over the years. My favorite trick is to walk through the paint department at Home Depot on the way to the registers and grab a handfull of those big wooden stir sticks... the ones for the 5 gallon bucket. They make great backers for sheetrock patches. For some reason they tend to split less than 1x2s, and they're free.
The biggest thing I have learned is to do as much smoothing as possible while you're applying the mud. But be sure not to build it up too much. You will need to sand and re-apply at least twice.
Good luck with the "covert operation" since the entire room will likely be covered in white dust from the sanding!
One of my favorite tricks for small patches is online somewhere, but I can't find it. I'll describe it as best as possible, but it's hard to put into words. Say you have a 4"x 4" hole. Cut a 6" x 6" peice of sheetrock, then cut the back side through the paper and most of the filler, in a 3 7/8" x 3 7/8" square leaving the face of the paper intact. When you're done you'll have the front sheet with a chunk of drywall that will fit perfectly into the hole in your wall. The "flaps" around the edge can be buttered with drywall mud and act as both sheetrock and tape! Like I said, hard to explain, but it works. For smaller patches, you can get away with only one touch-up coat of mud.
Happy patching!
Heath
audtatious
240marcuSX wrote:There is one stud about a centimeter away on one side, but on the other side there isnt one anywhere near. If the hole were more directly over the stud I would just use the stud.
Unless it's an old house, studs are typically spaced 16 inches on center. Make sure you use drywall mud and not spackling as that crap is a pain to try and sand. Use a large trowel as well and spread the mud at least 6-8" passt the seams to ensure a smooth blend.
Q451990
I finally found a link to the method I was trying to describe...
http://www.naturalhandyman.com....html
Heath
240marcuSX
Car: E34 525i
E46 M3
Thanks for the help guys.
I got it patched up, It just needs to be painted. The dust did get all over everything, but Im going to call this mission completed.
The other hole that I have is just going to get some drywall compound, I dont think I need to cut out a patch of wall to fix it.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
^ there's no need to paint it.Just pull a redtop and put a lamp over it.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
It's gonna look like *** with that patch kit. Here's my attempt at patching.
zer...age=1
Just pay someone professional to do it. Trust me. If you want to do it, just cut a piece of drywall to roughly fit and use spackle to fill in the spaces.
Return to “Around the House”
