l80_240 »
https://forums.nicoclub.com/l80-240-u35367.html
Fri Jan 02, 2009 3:25 pm
i have the gtech rr and as long as the weight is correct(you can add differnt cars, cylinders, weight, shift points ect, look it up...) it has always been within .2 sec, can be a bit tricky when you spin the tires or stall out then it seems to miss, but as long as you have your weight and a good mounting location it should be just fine, even more for finding g forces or just having fun because (with the gtech) you can put it in any car. my personal experience is only with the gtech, but i wouldnt see how much of a differnce the passport would do.
