I am Technoman wrote:If you need to pass smog with a hotshot header and you have ODB 2 this is my recommendation. Buy a very good aftermarket CAT. Have it mounted on your car buy a very good welder NOT HALF ASSED! Do NOT plumb your FRONT 02 sensor into the hole in one of the runners hotshot says to put it in. Why would you want get a reading from only one cylinder? That’s stupid I think! Put the front 02 sensor into the back of the header in the collector were Hotshot says to put the back 02. Have the welder weld in a bun hole in the pipe AFTER THE CAT. This is were your rear 02 will go. By doing it this way you’re going too make awesome power and get a better 02 reading because you’re reading on ALL cylinders not just # 3 and you will not get a engine light because you have a CAT and everything is RIGHT!
That's EXACTLY how my car is done. I moved the front sensor mainly for asthetics, it was only afterward that I realized it was a better place for it. FYI, Random Technology makes a bolt on cat with the rear sensor bunge already welded on, available is 2.5" and 3". I tossed my rear sensor completely though, and it still passes, cleaner than it did when new. Helps that the PCV, EGR, and breather are no longer used.
