jacob360 »
https://forums.nicoclub.com/jacob360-u6512.html
Mon Apr 14, 2003 7:30 am
EGR isn't the only reason the sr20det fails visual. It fails because it's a JDM motor. Even if the smog tech thinks it's the stock motor, he would ask if you have an EO number for the "turbo kit". The only way you can get an sr20det legal is to go through the Smog Referee, and they would never sign it off. I currently work for the Referee doing smogs. We just finished signing off a guy who swapped a 98 USDM GSR motor into his 96 Civic, and he had to go through tons of bullsh*t just to get it done. Imagine what it would take to get a JDM motor done, if it could be done at all.
If you got your sr20det smogged in Cali, then you got an illegal smog, and you better remember where you took it so you can go back in two years, cause guys that will risk there smog license passing Jap motors are sometimes hard to find.
Cali smog laws suck. I figure, if the numbers are clean, then who gives a ***** about the rest. But that isn't the way it is. When I do my sr20det swap, I'm not even going to try to do it legally. Even the Ref I work for told me I'm going to have to get an illegal smog. He doesn't care, cause he's cool, but he does his job right and would never let anything slide.
If you ever get a registration that says you have to go to a Test Only Center, put the stock motor back in. Don't even think about showing up with the sr20det installed, unless you got the ref to sign it off, and he gave you a BAR label.
If you have any questions I can ask the Ref and find out. There are a few things I still don't know. Recently they started allowing JDM motors to be installed, but they have to be configured very strictly to the vehicles original stock emissions equipment, and I think it has to be the Jap version of the same US motor. I'll find out more about that tomorrow.
PEACE
