Passing Emission with a SR20DET in Washington (Clark County, Vancouver)
xtypical360aznx
Car: 89 Fastback w/ Redtop T28
I live in the state of washington, in clark county, the city of Vancovuer, So I've heard that you can't have aftermarket turbos. I was going to run it through just to see but then if it didn't work out. I was thinking maybe drop a KA back in just to run it but its just too much work. but then it came to mind. Don't 200sx run SR20DE(non-turbo). Could it be possible to like get a exhaust manifold from a 200sx and swap it over and remove all the turbo parts. Or if there is a place i can get sr20de exhaust manifolds for 240sx's.
partymonster 975
Car: 03 Maxima SE, 94 Corolla
There's gonna be a lot more work involved then just the manifold. ummm, do you guys have visual up there cuz you mite have a chance of passing with the stock turbo and injectors. It's been done around here a few time. And I guess buy a CAT.
xtypical360aznx
All my cars ive registered and had to go through emissions were all sticking tubes up the exhaust. and doing the gas cap check. they'benever check the engine. im just afraids they might smart when the blow off vavle goes off. and plus all that o2 bio **** i dunno when theystick the tube up my ***. wouldnt it be over the legal limit having the turbo. it is a stuck turbo and injectors
partymonster 975
you mite pass but yea, the bov mite cause a problem. What kind is it? since u can always disconnect or recirculate.
xtypical360aznx
bov?
partymonster 975
blow off vavle
xtypical360aznx
TurboX and HKS SSQ
partymonster 975
u have 2 blow of valves? Which r u using right now. Cuz If its the HKS they make a recirculation kit that I belief is like super cheap.
xtypical360aznx
TurboXS, the HKS SSQ is a spare when i bought the car
