Iguanaman »
https://forums.nicoclub.com/iguanaman-u99409.html
Wed Jun 18, 2008 8:09 am
I have an issue on my 2000 I30. When I use the auto-up feature on the passenger window, the window goes all the way up, then pops back down a few inches and stops. If you hold the window switch up, then when it's at the top, engage the window lock, release the window switch, then disengage it, the window stays up just fine. The dealership said they've tried to adjust the window motor timing (?) twice and it didn't work, and now they're recommending a motor replacement at $400+. Somehow I doubt the issue is the motor. Anyone seen this problem, and know the fix? Is it something I could fix myself?
Thanks in advance.
