Passenger window won't move
jsm02cpa
Car: 2000 QX4
Ok, first, I thought it was just the switch, played around a bit with it after taking it apart, and it would move a little, tried to put it back together and it seemed like something was shorting, so removed the switch. It didn't ever blow a fuse, but now the window is down two inches and I can't get it to move from even the driver's side switch.
If the fuse didn't blow, could I have messed up the driver's switch as well for that window? Can that happen?
Anyone know a good place to get switches? Ebay has some for about $60.
I'm going to try taking the switch from one of the back doors and put it on the front to see if it will work.
I hope this didn't waste the window motor, but now it's not working at all...
Anyone have any experience with this. Thanks!
Kidastra
Car: 2003 Nissan Pathfiner
Try putting some current on the motor itself, 1 way will be up, reverse will be down. you can see if the motor is shot,
