b.mccorm11 »
https://forums.nicoclub.com/b-mccorm11-u255901.html
Thu Feb 11, 2016 7:12 pm
Much less elaborate than everything you've tried, but if you haven't I'd give these steps a shot, it resets the power windows. You'll have to give the motor a jump again, but it might be worth it.
1. Push the ignition switch to the ON position.
2. Close the door.
3. Open the window more than halfway by operating the power window switch.
4. Pull the power window switch and hold it to close the window, and then hold the switch for more than 3 seconds after the window is closed completely.
5. Release the power window switch. Operate the window by automatic function to confirm the initialization is complete.
6. Perform steps 2 through 5 above for other windows.
