Passenger Window Sags after being replaced
JL_12Rogue
Car: 2012 Rogue SL
Had our passenger window smashed out yesterday. Was able to locate replacement glass from a local parts yard. Followed the install tips I found here on the site. Window goes down perfectly, however when you put the window up, it the front sags immediately. When fully up, you have to pull the window toward the rear of the car an 1/8" or so to get it to seal up. I have a feeling this has to do with the regulator cable being out of adjustment. During the break in, the cabling for the regulator had fallen off. I'm hopeful someone may have a diagram of how the cabling should look / ways to adjust the window. Its close, but not right. Thanks!
Sigster
Did you use/follow the factory service manual ?
http://www.nicoclub.com/FSM/Rogue/
fwd.pdf is the TOC/Overview,
the glass section is in the gw.pdf file
http://www.nicoclub.com/FSM/Rogue/2012%20Rogue/GW.pdf
JL_12Rogue
Car: 2012 Rogue SL
I did use a Nissan guide, but it was no where near as descriptive as these documents are. Many thanks for sharing! I found the diagram I was looking for on GW-23. I'll be saving this thread to my favorites for sure.
Return to “Rogue Forum”
