Poyzinous »
https://forums.nicoclub.com/poyzinous-u125838.html
Tue Jul 07, 2009 12:35 pm
It needs to be timed. To do that quickly, remove your door panel, locate connector from window motor to harness. make sure glass is rolled up all the way. Disconnect harness. Reconnect harness. roll down in manual mode, roll up in manual mode. Roll down in auto mode, then up. If it drops back down, you'll have to do it the other way, pushing the button on the motor and teaching it manually. Somewhere here there is a thread on doing that I think....
