truckboy »
Wed Sep 01, 2010 5:22 am
With that age of a vehicle I might check , call around to the do it yourself auto wreckers and take one out yourself , plus you can either ask them or call around to a dealership to find out what yr and models have the same passenger door motors.
That way you can maybe pull one out of a newer vehicle etc.
Be sure to over haul the motor and any plug connectors , the switch and especially the ground to the motor bec sometimes it's just a bad connection and usually it's a ground rusted or corroded etc.
Any good auto parts supplier will sell them but check with places like Walmart too bec some places charge high prices for the tools and clips.I payed almost 20.00 for my solid tool that removes the door panel clips alone.
Hope that helps and best of luck. By the way it's wise to buy those new clips and the special tools bec you save the door panels from damages and really a lot of headaches in long run.
