Passenger window issue
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
Torqd
I'm having an issue with the pass. window. Whenever I hit the button to make the window go up it goes up , but then drops back down about four inches. Is this normal? If not any way to reset the windows I tried the search function, but couldn't find anything. Thanks for the help.
biggie
The 'quick reset' that sometimes works is to pull up the switch and hold it 5-10 seconds after it has reached the top.
Otherwise the only other one I know involves taking off the door panel.
Torqd
Tried the quick reset.......nothing. What do I need to do once I take off the door panel?
biggie
When I search the G section this was mentioned from a Maxima fix:
http://www.nicoclub.com/archives/maxima ... epair.html
Also if you look in the FAQ stuff in G series General Chat there are the links for FSM and there is a reset procedure in there I believe.
Torqd
Damn, thanks for the find I will try that tonight. Appreciate it!
Return to “G35 and G37 Interior, Exterior and Audio”
