passenger side window wont go down
ulices09
Car: 1989 240sx
hey so i have a s13 and my passenger side window wont go down, it has power windows and im sure the motor is done or something like that not sure. mainly wondering if thats an expensive thing to get fixed, and if i can fix it myself.
tlkq
ok....ive done this before...make sure the little window lock switch isnt on...it only locks the passenger side and it locks both the driver side switch and the passenger side switch out
ulices09
Car: 1989 240sx
i tried that. but when i push the button for the window to go down it makes a noise but nothing goes down
SturgeonGeneral
its probably the amplifier for the window motor. They go bad all the time, there like 100$ from nissan, or you can buy them from a junkyard for dirt.
plane16j
Car: 91 nissan 240sx
mine does the same thing. i used to have to hit it, then it would go down . then it stopped workin period. now when i press the switch theres a faint click inside the door and thats all...i need help too.
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Have you tried holding the door open and then trying the window? Sometimes the wires weaken in the door hinge area, moving the door to the open position may make a better connection. Audis are famous for that one.
LiLDueceCoupe
Car: 1993 nissan 240sx coupe
Ya my friend went thought that and we just went and replaced the motor for about 200 plus i got 20 for the labor its an easy fix if you've done it before but you would just be better of replacing the motor and i suggest a junk yard because 200 for a p/w motor is b/s
