ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Thu Aug 02, 2007 12:11 pm
You really should take the door panel off and look to see what's wrong. I've had to use stiff wire to reconnect the little square ball on the cable to the plastic (you'd know what I mean if you saw it). The plastic piece is formed onto the cable and loves to break away from the cable. If there's something jammed in the track, you may just be able to un-jam it and put the door panel back on. Do an autopsy and see what you need is my suggestion. Otherwise look on ebay, this forum, or junkyard for a replacement. If you think it's brushes in the motor to blame, turn the key on, hold the little switch in the window up position, and slam the door shut a few times while holding the switch. That'll often times free up a seized power window motor and get you back in business. If ya don't use it, ya lose it! However, with the crunching noise I'd just take the door panel off first.
