Passenger side window
idamaster
Car: 92' 240sx, 98' 328i
It wont open. The other one does. It had been raining earlier but i had the windows down, went inside the store, came out. When i got into the car neither would open but then the left did but its been 2 days since this happend. Whats the problem with it. Is it the motor?
Klits562
Car: white s13 coupe
make sure the p/w lock isnt on its a rectangular button above the window controls it will lock the passanger side window but not the driver side making you think the passenger side is broken. This happened to me just a few days ago lolif thats not your problem check fuse then check motors
Wretched
Car: 93' Hatch
So the pass. side window no longer works? Does it work with the passenger switch? Check your fuses. Also try pulling the door panel and banging on the motor while trying the switch.
LoserCard
Car: Forest Green 1993 240SX SE Fastback
Probably the window amp, open the driver side door, open the amp up and check for broken solder. I think there is a write up somewhere in the tech section.
idamaster
Klits562 wrote:make sure the p/w lock isnt on its a rectangular button above the window controls it will lock the passanger side window but not the driver side making you think the passenger side is broken. This happened to me just a few days ago lolif thats not your problem check fuse then check motors
I already tried this about 10 times but now it works. You have no clue how much of a dumbass I feel like I am right now. I know the reason why, when i press the switch for the passenger window there is a short pause before it starts going down. I already had fixed it before but i changed it back. haha
Modified by idamaster at 2:23 PM 10/15/2009
