Passenger side rear door won't open
supersnake83
Car: Infiniti J 30
Hi everyone,
Does anyone know how could I take the rear passenger door panel off while the door is closed?
My door is stuck, and I believe that it is a broken handle again. The same thing happened to the driver side rear door, but then I had someone take it off for me (same situation: door did not open, broken handle)
If anyone knows, a reply would be greatly appreciated.
Thanks,
Geoff.
P.S. Just some extra info!
When this happened the first time, I repaced the door lock, handle and actuator because the handle was cracked on the inside. The feeling when I try to open the passenger side rear door is the same as before with the driver side rear door, when I pull on the handle, it feels like it is not connected to anything. (it is really loose)
If you have anymore questions, reply and I will get back to you today.
scottj30
Car: infiniti j30
im having the same prob woundering how u fixed it
DominickJ30
Car: 1993 Infiniti J30t
Instead of pulling the handle out, try to lift it upwards.
scottj30
Car: infiniti j30
tried hitting it everything do u no how i could fix it
supersnake83
Car: Infiniti J 30
Hi everyone,
I actually fixed the problem. The problem was the handle on the inside. The spring that is connected the the rods were severly rusted. I got it open one day by luck, because it just decided to work one day. That is when I just took the panel off until I got the parts.
I just replaced the handle. I got it from a salvage yard for about five dollars.
If you have the same exact problem, what could fix it, if it is the spring, is to just soak the spring with WD40 oil to loosen it up.
Geoff.
scottj30
Car: infiniti j30
Can i get the door panels off without damaging them?
