Passenger side headlight help.
mrb63083
The other day i noticed my pass. side headlight went out. So I did the easy thing and went to Autozone and got a new bulb. After i installed it, i turned my headlights on, and nothing. My friends told me before that sometimes my headlight would go out, but then sometimes it would come back on. What is going on? I checked the wiring to the main harness, and it looks fine. Then i checked the fuse for the right and left headlights, both were fine. What would be making my headlight not work?
Thanks.Marshall
Anand
Car: 95 Nissan 240SX
if it is intermitten, then there is something wrong with the wiring...
maybe the ground wire is loose??
mynameisjonas
yeah something is definately not making contact. make sure the headlamp plug is in good shape.
