Passenger Side Door Gap / Transition
PerformanceSound
Car: 1991 300ZX NA 5spd 2+0 (2JZ swap)
Guys,
Just want to see if anyone else has noticed this similar thing on their Z32's.
Mine seems to have a slightly uneven gap/transition on the passenger side door between the door and the dashboard. It looks like the door padding is elevated a bit more than the dashboard padding. Is this normal on all Z32's?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
That doesn't look too terrible, possibly just some warping through the years.
DCaff300ZX
Car: .
1993 CRP TT- Modified
Agreed, nothing to worry about as both of mine have had the same "irregularities" if you will in the height of the dash pad and the door card, and spaces between the door card/dash pad and cloth/dash pad.
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
Be happy. In the Texas heat nothing stays nearly that close at all. You can see there that the dash material is already starting to pull inboard due likely to getting hot.
DCaff300ZX
Car: .
amc49 wrote:
Fri Jun 15, 2018 10:58 pm
Agreed, nothing to worry about. It's due to the fact the door cards are flimsy cardboard-ish material that loses it's rigidity and shape after time and many hot/cold cycles, plus in my case at least the humidity in Washington.
