Karthur »
https://forums.nicoclub.com/karthur-u296510.html
Thu Jun 13, 2024 3:06 pm
2016 Rogue - SL Model
When there is a driver AND passenger and I start the car, both seatbelts have to be fastened before the seatbelt light in the instrument panel will go off, which is normal. Also, the passenger airbag off light is NOT illuminated. This is the way things should work.
Now with just the driver in the car, after starting the car, the seatbelt light is ON. The passenger airbag off light is illuminated. The seat belt light will not go off until I fasten BOTH driver and passenger seatbelts.
The sensor in the passenger seat seems to be working because the passenger airbag light goes off if a person is seated there. Any clues what's up with this?
Thanks
