passenger door panel removal
reno6621
Car: 1992 nissan pathfinder
How to remove the rear door panel for a 1992 nissan pathfinder?
analog154
I have a 2003 but I suppose it should be similar. You first take the trim out around the door handle. Then remove a cap in the door which is covering a screw in the side of the arm rest. Remove the screw. Then pop the panel where the window control is on up and un harness the window control and unscrew the screw under there. Then just take a flat head screw driver and pry under the edges of the door to unclip the clips.
