passenger door locks but isn't locked
northShoreQ
Car: 1994 Infinity Q45
Hello,
My passenger side door locks automatically and manually. The little lock handle moves to unlocked / locked position fine. However when you go and try to open the door when it is susposed to be locked it opens fine. Sometimes it sets the alarm off sometimes it doesn't.
Any possible solutions? Kinda sucks having 1 door that never locks now
Thanks
96Qowner
Car: 1996 Q45
Your actuator rod may be busted - simple lil part, but a biatch to get at. Here's some background info from past threads:
zerothread?id=180860
zerothread?id=135059
northShoreQ
Thanks for the reply.
Forgot to add that the door opens fine and that the key spins around a near 360 degrees in the lock.
96Qowner
Car: 1996 Q45
northShoreQ wrote:Forgot to add that the door opens fine
Probably the same mechanism
northshoreQ wrote: and that the key spins around a near 360 degrees in the lock.
A good clue. Read through that second thread carefully - lots of detail there - might be able to figure out exactly what's broken.
northShoreQ
hmm yes I will take door panel off if it stops snowing sometime today
Thanks for the help.
