pathman1 »
https://forums.nicoclub.com/pathman1-u185796.html
Sat Jun 11, 2011 8:12 am
The problem is the weird handle on the door. If the wont open using any means possible you will have to remove the interior door panel. It can be done with the door in the locked and stuck position. Remove the trim around the out side of the door. This the the rubber weather stripping. Then remove the 3 screws that are located behind the two knock out round groumits. One is on the door pull and the other is larger and on the arm rest. Then pull up on the power window pad. You will find the last screw that holds the door panel on. Next with the window up pull off the door panel and lift to remove. Locate the bar that runs up to your outer door handle and pull it to release the stuck door. After the door has been opened remove the outer door handle. Two bolts behind two rubber groumits. After the handle is removed inspect the outer handle. Mine was rusted in the stuck position and would not release causing the door to be in the locked mode. The outer handle after it is removed will need to be wd40 ed or greased . I used the white grease. Spray the spring and work it real good before reinstall. During this process if the rod that goes from the handle to the inside of the detaches dont panic , just slide the rod back down thru the door and set it back in place into the blue clip. It took me about 45 minutes the hardest part was removing the door panel. Hope this helps.
