There's an interesting article here: http://auto.howstuffworks.com/car-drivi ... s/ocs1.htmSince Sept 1, 2006, NHTSA has required new vehicles come with advanced frontal airbag systems. Advance front passenger airbags can also — based on your weight and position — turn the airbag off. These new models are configured to render moot — the belief that the airbags crushed children and small adults — the public outcry over first-generation airbags. Mechanics were regularly asked, against the wishes of manufacturers, to disable passenger-side bags. This led to the introduction of controversial on/off switches — which are still permitted until 2012.
The 2015 Rogue Owner's manual states on page 1-58 if the occupant is a small adult the front passenger air bag is suppressed. I did not see a weight limit in the manual so "small adult" is subjective. I suggest you call Nissan Customer Care and tell them you want an answer on what the weight limit is. Tell them this is a safety issue and you are going to pursue it until you get an acceptable answer from them. Tell them "Your wife probably doesn't weigh enough is NOT an acceptable answer". Someone within Nissan knows what the weight limit is..mpscotia wrote:Any updates? My 2015 is doing the same thing. I'm pretty sure my wife knows how to sit in a seat properly, but the airbag light stays on.
You could try taking her through McDonald's a couple of times...nezoid wrote:We have the same problem... Just for reference, she is 5'4' 110. I told her she needs to gain weight, but that wasn't an acceptable solution for her.
Q: At what weight does the passenger-side airbag turn on or off?
A: Federal regulations do not specify a specific weight at which passenger-side airbags must be turned on or off. Instead, automakers must meet a performance standard that in a frontal collision the airbag protects a crash dummy that represents a “5th percentile female” and weighs about 108 pounds. Passenger-side airbags should be turned on when seat sensors detect an occupant of this weight or greater, but that doesn’t mean they will always be off if someone lighter is seated.
All airbag systems are not the same, so when the passenger-side airbag is turned on can vary by manufacturer and the readings from seat sensors that measure not only the weight but the stature and seating position of the occupant and other factors. For example, on some GM vehicles, an electronic field measures the amount of water in the occupant to help determine the occupant’s size and weight. The National Highway Traffic Safety Administration says an adult who is not centered and seated upright or is leaning heavily on an armrest can take pressure off the seat cushion and mislead the seat sensors.
When Occupant Detection Sensors Don't Make Sense?
On December 17, 2011, Hyundai settled, for an undisclosed sum, in a crash that wouldn’t and shouldn’t have caused a fatality but for a defective occupant seat sensor – a problem that may be more common – across many manufacturers – and more potentially deadly than realized.
On January 3, 2010, Donna Lynn Hopkins was a front-seat passenger in a 2008 Hyundai Accent, with her husband, Tom, at the wheel. As they approached an intersection on Highway 181 in Bexar County, Texas, another driver failed to yield the right of way. The Hyundai T-boned the other vehicle with sufficient force to deploy the airbags. But only the driver’s airbag inflated. The occupant seat sensor mat in the front passenger seat determined that, Donna Hopkins, a 165-pound woman, was actually a child, and turned off the airbag. Worse, Hyundai’s sensor strategy also turned off the seat belt pretensioner. Like some other manufacturers, Hyundai’s occupant sensor is designed so that the front passenger seat belt pretensioner fires only if the airbag is deployed. Mrs. Hopkins had none of the advanced safety features needed to adequately protect her in that crash, even though she was belted, and weighed 55 pounds more than the regulated cut-off for smart airbag deployment. Her husband, Tom, walked away from the crash; Donna Hopkins died.
Not at all. There are studies out there that show you may be at higher risk for injury if you are not an adult. Here is one such study:followingnfront wrote:So anyone who weighs less than 125lbs sitting has a risk for higher injury in the 2015 Rogue because the airbag wont deploy... Great. So much for safety
Thanks for the info on this Dave. I did a google search on the OCS and there was several hits on it, including a March 2014 recall by Nissan to fix problems with the system in certain vehicles.dave08902 wrote:The new Nissan's has a new system for passenger seat weight detection, it is called Occupant Classification System. It has a programmable module under the seat and it looks at the actual weight of the person and the seat position forward and aft. When the airbags deploy, it uses this data for how strong to deploy the bag. If you disconnect any connectors to the airbag system, it will need to be re-programmed. First you hook up your Consult 3 or any professional scanner, then select body - Airbag - and then select Zero Point Reset. When doing this reset make sure the vehicle is level and do not bump or cause any vibration otherwise the reset will cause the light to come on. It takes about 1 minute. If you can't do it yourself, ask the dealer about it.
