Passenger Airbag/Airbag warning light flashing
ssjones
Car: 2008 Nissan Altima SL 2.5 Sedan
Folks:Installed my new head unit today and on completion my airbag light is flashing on the dash. When I start the car, the airbag for passenger light flashes off, than goes dark. I definitely plugged it back in.Of course, I pulled the dash vent and unplugged the airbag light for the installation. I tried pulling the positive battery but that did not reset the light. Any ideas on how to reset this light? (or will it reset after a number of starts?)__________________
bradz
Car: Altima Coupe
We've been discussed this problem before, check this out: zerothread/256678
ssjones
Got it, followed this regimen:Turn ignition switch from OFF to ON. Air Bag warning lamp is on for 7 seconds and turns off, the turn ignition switch OFF within 1 second after the lamp turn off. After ignition switch is turned OFF, wait for more than 3 seconds. Repeat steps 1 to 3 twice. (Perform 3 times in total.) Turn Ignition switch ON. The SRS lamp has been reset it.You must time it pretty acurately it took me about three times but it worked
