Passed Emmissions
Red-KAT
Car: 1995 240sx-se ka24det
Passed Emmissions
HC Cruze Limit 150 me Cruze 76Idle Limit 220Idle me 46
CO(%)Cruze Limit 1.1me Cruze 0.45Idle Limit 1.2Idle me 0.02
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
do you have any of your emissions equipment eliminated? doesnt the greddy kit hook to you stock cat/ exhaust and have a EGR hookup and all that good stuff?
Red-KAT
Nope I have My EGR and a Catco 3" CAT. I dont have my second 02 installed so I just reset my CEL right after I pulled into the station.
The only things I did were backed my timing off by 2 and put -5% air across the whole bottem end to lean me out... (I was running 15.5 AFR at idle) Thats one good thing about the E-Manage is I can just screw with it right before the test and drive away fine after.
Bronze MFP
thats good news. i'll have to run my egr and all that mess. NC has emissions testing too How do you reset the CEL so fast? i thought you had to mess with the ECU by turning a screw on it or something... forgot the details, but it didnt sound like a 5 min affair
PapaSmurf2k3
Site Admin
just un-plug the battery for 15 mins or so
Red-KAT
I have an OBD2 port... I got a hand scanner for reading codes a long time ago and it resets the codes within 5 sec. The second 02 takes a little while to trigger a code.
veilside180sx
Good job man.
turbo98_240sx
Car: computers, cars, anything that can do something and be made to do it faster stronger or better
good to know sooner or later my car will have to be tested (wisonsin) and none of my buddies work at the test station any more so i will have to pass for real this time hehe. I've been working on er for a few day now and hope to have er up and running soon
Drift Machine
Car: 1991 KA-T 240sx
You gave me hope Red-Kat, I'm suppose to get my KA-T emissions tested this summer (Snohomish County). Though I think I may just try and get it registered to my grandmas house (Island County).
TheOne
Car: 93 240sx FB
lucky you!, i still got my STOCK ka with everything stock, and i didn't pass cause some of the side marker lights were DEAD!!!!!!!LMAO.(i didn't have to pay for the testing though, and just got the lights fixed).
i always though leanin the 1000 and 2500 rpm parts would do it, since thats the rpm where they usually test it at.
NateDogg
How did you retain the EGR?
Red-KAT
Modified Greddy kit... So all the stock emmision stuff is installed. (Except the second 02 but thats my fault)
It would not be hard to make a downpipe that would keep the EGR. A lot of people take it out. But I dont think it causes much harm if I leave it.
Jookmasta
good to hear that u passed. i myself wont b worrying about that since in fl there is no emissions. i probably would fail as i have virtually no emissions things on my car (cat, egr, etc.)
WDRacing
I have to register in another state. The only thing I have installed now is the IACV and the MBC Power Assist Vac Line. The rest go to boost related things.
onosqv
Car: '92 240sx Vert
WDRacing wrote:I have to register in another state. The only thing I have installed now is the IACV and the MBC Power Assist Vac Line. The rest go to boost related things.
Oooo, that's an idea. How complicated is it to register the car in another state? I would imagine it is kind of a pain w/ insurance & whatnot.
I do have a sis who is currently in Nevada, but problem with that is I think Nevada has emissions testing too.
***EDIT: o yea, congrats Red-Kat on passing emissions :-D
MarkEmark
Car: fully-built '95 240sx KA-T
Red-KAT wrote:Passed Emmissions
So I take it Washington doesn't test NOx emissions?
WDRacing
Its easy for me, I'm in the Military, I can switch states of residency just by changing my mind and filling out a form. Then I call the DMV, re-register and they send me plates
veilside180sx
Nope Washington doesn't test NOx, but Oregon does. Although outside the metro area doesn't have emissions testing in Oregon. I thought AZ was the same, but I guess not.
