passanger turbo failed need to upgrade
Jayjay228
Car: 1999 300zx twin turbo
550cc injectors new style withfuel rail adapter
chipped ecu
HKS HYPER exhaust
hid kit
hi so after a few months of not having my z due to no power and wont rev past 3500 rpms and contionues smoke my mechanice called and said my passanger side turbo is shot so i figured to upgrade now i just want a fast car for a summer car daily driver.i have upgraded 550cc injectors and chipped ecu for injectors from zconcept performnce and ideas suggestions thanks in advance!
[youtube]http://youtu.be/zpBmQM_p698[/youtube]
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Well, let's get down to basics. How much power are you wanting to make?
Jayjay228
chipped ecu
HKS HYPER exhaust
hid kit
not to sure. i know i want a car that ppl will talk about.i had a real bad mis fire and ran at the track 1/8th of a mile i ran 10 secs around there .thats a good question tho i really dont know how fast i would want it can you help me out?
Jayjay228
chipped ecu
HKS HYPER exhaust
hid kit
Ace2cool wrote:Well, let's get down to basics. How much power are you wanting to make?
thanks
Shoey2
Car: 1990 300ZX Fairlady Z Twin Turbo
make it run properly stock before you start trying to make power, or you will likely be chasing problems after you build it that have nothing to do with the mods you do. best way to build a car is start with the cleanest best running car you can. you can buy just the center secions of the turbo and rebuild them for 500 bucks...thats what i would do. you can make more then enough power for a daily driver on stock turbos with a boost controller, injectors and tune.
Jayjay228
chipped ecu
HKS HYPER exhaust
hid kit
Shoey2 wrote:make it run properly stock before you start trying to make power, or you will likely be chasing problems after you build it that have nothing to do with the mods you do. best way to build a car is start with the cleanest best running car you can. you can buy just the center secions of the turbo and rebuild them for 500 bucks...thats what i would do. you can make more then enough power for a daily driver on stock turbos with a boost controller, injectors and tune.
that's a. erg good point you made thanks but I trouble shooter everything else and that has to be it and I just want to upgrade my turbos now and get that out of the way I'm just confused on witch turbos to get I want to get a fuhe ll exhuast system to with t
NolimitZ32
Here is the thing: upgraded turbos are great but they perform much better with better mani's and freeer flowing piping and better intercoolers, just this packege not counting the turbos will run you around $2300 ad a set of nice 550BBs or Discos and your out another $2500. It starts to build up rather quickly, it you're ok with just having stock manis and want some fun responsive turbos I'd say go for the 550BBs, all the fun without the lag. Any bigger and you will start having lag. Basically what I am saying is don't think you'll just get away with putting on new turbos, plan yur build and plan it well because when the mod bug bites is a mild fever, but when the Z32 mod bug bites its a lifelong disease.
Jayjay228
chipped ecu
HKS HYPER exhaust
hid kit
NolimitZ32 wrote:Here is the thing: upgraded turbos are great but they perform much better with better mani's and freeer flowing piping and better intercoolers, just this packege not counting the turbos will run you around $2300 ad a set of nice 550BBs or Discos and your out another $2500. It starts to build up rather quickly, it you're ok with just having stock manis and want some fun responsive turbos I'd say go for the 550BBs, all the fun without the lag. Any bigger and you will start having lag. Basically what I am saying is don't think you'll just get away with putting on new turbos, plan yur build and plan it well because when the mod bug bites is a mild fever, but when the Z32 mod bug bites its a lifelong disease.
I plan on doing the whole exhuast system now with the upgraded turbos.including manifold so I herd a lot of talk about t28 will that've a good choice and have you ever herd of concept z performance that's where I plan on ordering from are there pricess good
Ace2cool
CZP is a reputable dealer.
Jayjay228
chipped ecu
HKS HYPER exhaust
hid kit
Ace2cool wrote:CZP is a reputable dealer.
so what turbos guys? and exhaust system?
Ace2cool
Exhaust all depends on how much you're looking to spend. Same with the turbos.
GT28RS is the biggest turbo you can fit in the stock location with almost no modification.
Specialty Z makes a full 3 inch turbo back exhaust, but it's expensive. HKS Hiper system is a good catback, but looks like a** in my opinion. The new Z1 3 inch exhaust looks and sounds really cool. You just gotta do research to figure out what it is that YOU want. we can't tell you, "buy these parts because they're best." Every part has its own application.
Really, you need to set goals before you just go chucking parts at a car.
everything-you-need-to-know-about-the-z32-t508377.html
Read that. Most importantly, the part about halfway down, titled "Destroying the World in Your Z32: Tuning Tips"
You really need to do research before you make a decision.
Jayjay228
chipped ecu
HKS HYPER exhaust
hid kit
Ace2cool wrote:Exhaust all depends on how much you're looking to spend. Same with the turbos.
okay well so far im thinking about getting a
Garrett 300ZX GT2560R (GT28R) Ball Bearing Turbo Kit (600HP) w/ Downpipes $2595.00
AMS 300ZX Max Flow TT Exhaust Manifolds - Z32 TT $494.00
HKS 3106-EX003 300ZX Hi-power / Hiper Cat-Back Exhaust System 719.99
HKS Turbo Timer Type-1 Nissan 119.00
hows that am i missing anything? my mechanic is charging me 1500$ to install the turbos is that a fair price?and will everything i listed be okay?thanks guys
Quick Time Performance QTEC30 3" Single Electric Exhaust Cutout 162.00
HKS EVC-S 45003-AK009 Boost Controller - 300ZX 375.95
Ace2cool
Jayjay228 wrote:my mechanic is charging me 1500$
Might as well throw that money in the fireplace. I mean, if you have the money and don't want to do it yourself, by all means. As far as who your mechanic is, does he deal often in Z32's? These are extremely finicky cars, and most mechanics treat them like any other car, which tends to break things. That's why most of us choose to work on our own vehicles. It's cheaper, and you know the work is done right, even if it is harder.
As far as power, what are you shooting for? I'd just go for 12 lbs and that should sit you around 375-400. I wouldn't go past that on stock internals, but that's just me. Other will tell you it's fine, but that's them. If you're upping the boost, you'll need a new base tune.
Ace2cool
And are you planning on keeping the stock downpipes and catalytic converters? Cause that's a lot of restriction in itself.
Jayjay228
chipped ecu
HKS HYPER exhaust
hid kit
Ace2cool wrote:And are you planning on keeping the stock downpipes and catalytic converters? Cause that's a lot of restriction in itself.
the turbo comes with 3" dpwn pipes and im getting new exhaust system
Ace2cool
The HKS Hiper doesn't replace the catalytic converters with test pipes. And sorry, didn't see you wrote with downpipes next to the turbo.
Shoey2
still gonna need a 3 inch front pipe. what is the word on labree? all i hear about on here is B&B and hks. and the new 3 inch PG exhaust
Ace2cool
Labree TMK is the same thing as SZ and B&B. Well, maybe not nowadays, but they were for a while there.
