pass. power window won't roll down, help
Indolent
Car: coupe
91 se coupe ok my passenger window is stuck all the way up, won't roll down
-tried pressing the window lock several times, pressed down on both switches doesn't roll down, hear it wanting to roll up-tried a good working motor, plugged it in, pressing down in both switches, doesn't want to roll down, but when i press up it'll roll up-tried using good working cond. switches, no luck-checked fuses, doubt it's a fuse since my drivers window works, and the pass pwr window wants to roll up
any help towards this problem is appreciated
szucceedly
Car: 96 240sx SE
hey there...i have the same problem...but opposite of yours. mine will roll down but won't go up. did you find the solution?
Indolent
Car: coupe
yes i'm late, jus figured it out, the switch on the s13 one was too hard, the copper piece wouldn't touch to make the connection to roll down, so i got one off a pathfinder (same swithc) and it was significantly lighter, so when i pushed down it went down
