I have a few parts that I need and question that need to be anwsered before I start my RB20 in S14 swap. I appreciate any and all help and suggestions.
1. Downpipe-does anyone make one that we know is a direct bolt on and doesnt rub. If not, will a 3 inch sr20det work if I cut off the flange and have it welded back on 180 degrees. I want to keep my cat, so anything that excludes it is not a option.
2. What fans work the best. Whats the lowest cfm you would go with. Will pullers fit if i'm using the R32 crossmember.
3.Will an Exedy stage one be good enough for 300rwhp or is a stronger clutch needed.
4. Looking at Wolfgangs wiring guide, has any one confirmed this on the 96-98 S14s
5.Where is the best place to get these gaskets and seals:valve cover, intake manifold, exhaust manifold,front and rear main seals. I heard rbmotoring was priced decent, can anyone confirm.
6.My clip has 60xxxkm or 40,xxx miles on it, the timing belt,oil pump, water pump all look easy enough to change after the engines in. Can you give me any other reason I should do any of these now. I'm going to do them later as more preformance mods are added. Im just trying to find the cheapest and fastest way to get the engine in the car.
Sorry for the long post. I have search these topic for about six month and didnt come up with any definative anwsers. Thanks again for any help or suggestion.
