1. i would reccommend a different picton, CP, wiseco ...someone like that 8.5:1 or 9:12. also eagle rods are a good addition 3. ARP head stud kit 4. possibly use ARP for rod bolts etc. 5. good piston rings, JE, Wiseco, along those lines 6. Replace the rod bearings also, aftermarket or stock 7. need to do some head work also, cams, springs, retainers, rocker stoppers, etcoh and good luck on that 500 mark!afmafia wrote:what parts to i need to build a 400-500hp sr20 motor bottom end ????
good tunning will make all the difference plus u need a string blockTurb0wned wrote:not part of the bottom end but.... GOOD TUNING
