parts that fit on pathfinder
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
Will a 3.3l xterra aem intake fit on a 2000 3.3l pathfinder? AND Will 2000 xterra rims fit on a 2000 pathfinder? and if you are wondering, these are the rims... http://www.courtesyparts.com/M...D2020
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
im not sure baout the intake, it would probably "work" but you may have to mess with it to get it to work just right, but id say itd probably be fine!!!
For the wheels, the bolt patterns are the same, so id say they would work just fine...
pathfinder_se_black
thank you, i was just wondering because my friend has an xterra and i have a pathfinder and we have the same exact motor vg33e
elwesso
2007 BMW M Coupe
might as well try it then... Welcome to NICO, BTW!!
pathfinder_se_black
thanks, ill post pictures up soon
jhonny
do u think those rims would fit on a 06 pathfinder???
pathfinder_se_black
check the bolt pattern, im not sure if the bolt pattern changed on the newer models
elwesso
2007 BMW M Coupe
the newer (05+) pathy is completely differnet, they use a 6x114.3 bolt pattern vs something else, so it wont work.
