parts question
The_Pretender
Car: 1991 240sx hatch KA NA everyday
got a guy needs a transmission. would an auto trans from a 95 be compatible with a 92? if not anyone in the georgia area got a trans for a 92 theyd sell?
EQwhipD
Car: 1994 Q45 (Totalled)/ 1994 Q45a (SOLD) / 1990 Z32TT
I believe that all Q45's from 90-96 had the same transmission. The difference is that 90-93 had 2nd gear starts, which is controlled by the TCU which is located below the rear deck of the car. Long story short, same transmission.-Evan (NC)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Read the sticky in the Articles.
Different 1st and 2nd gear ratios.
TCU controls the shift and gear start.
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
The_Pretender wrote:got a guy needs a transmission. would an auto trans from a 95 be compatible with a 92? if not anyone in the georgia area got a trans for a 92 theyd sell?
I have seen these from 90-96 and there are differences internally and externally on some of these. Some have a solid bellhousing. Some have the holes cut in the bellhousing to access the converter. Some have the small fluid cooler at the front base of the trans pan. Some have drain plugs from the factory and some do not. 95-96 models has a totally different bellhousing with vented slots for cooling and when taking apart the bellhousing the shaft remains attached to the bellhousing instead of staying attached to the transbody. Also has different style starter housings so U can't just bolt just any starter up to any trans.90-94 starters with gear reduction and 95-96 are the same. This helps U also if U know that 90-94 starters are the same which tells U that the bellhousings are the same also and the same for 95-96 same starter ssame bellhousing.
Rex
Car: None
My 95 has a 92 transmission in it .. actually it's had 3 different 90-93 trannies in it in the last couple months .
