SpeedKreature »
https://forums.nicoclub.com/speedkreature-u82308.html
Mon Nov 26, 2007 7:47 pm
Hello to all! This is the obligatory first post message! Weee!. Enough of that, on to the meat.
I'll admit the title is not the greatest in the world so I'll elaborate.
I formerly owned a '96 Altima and an '04 SE-R Spec V. I learned from both that my reflexes aren't fast enough to keep up with the weight of my foot. Neither had ABS. Enter the 05 GTI. ABS, ESP...Conditions had to be severely unfavorable to get it to slip. However, at 17mpg, it had to go and I thought something more utilitarian would be great. I now have an '07 Honda CR-V, also with traction control and ABS.
I haven't test driven a Versa yet so I cannot determine if the ABS will have enough of an impact on stability to warrant it's presence in the car so that leaves me with my question:
Are there any issues with performance mods needing to be tweaked, modified or simply not fitting as a result of ABS? I ask because this was a problem with both the Altima and even more so with the Spec-V I owned.
My reaction times are not so slow that a fantastic set of brakes, pads, lines etc coupled with adequately modified suspension and great tires wouldn't compensate at moderate speed. However, I have experienced that brakes on the sub 25k segment are more prone to locking up than I would consider acceptable and I'm not looking forward to dropping 5k right off the bat.
