Parts Compatibality
mindovaanything
Car: S13 Hatch
I just want to know if the following parts that I ordered will work on an rb, or sr or if I should just return them. All parts are for ka24e
Parts I'm questioning returning:
Exedy oem replacement clutch kit
Distributor rotor & cap
Spark plugs & wires
PCV valve
Parts that I am definitely returning:
PS, AC, & ALT belts
Intake & Exhaust manifold gaskets
Rear main seal
Clutch master & slave cylinder repair kits (turns out the issue with the transmission was the clutch release lever)
Parts I ordered that I plan to keep:
Tie rod ends
Sway bar link
Rack & Pinion Billows
Fuel Filter
My original plan was to repair my Ka24e and do a swap later on but, the engine got wrecked when the bolt holding it onto the hoist broke :facepalm: and the motor crashed into the ground, snapping the intake manifold in half and damaging a lot of the engine parts beyond repair. So now I'm planning to do a swap soon :naughty:
Hoffman5982
Car: '95 sr20det 240sx
I might be wrong, but I don't think any of those will work, with the sr atleast. I'm pretty sure the only thing you can use on an sr from a sohc is the MAF
Dattebayo
You should get a bigger fuel filter first, and the only part you could keep would be the Clutch master & slave cylinder repair kits.
You should also learn the proper points for hoisting the engine from the FSM. It's not like you can just sling a chain anywhere on the motor and lift it. There will be those who say they have done it, but it's not right.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
what the hell. 4 cyl vs 6 = different unless you mean youre not using some of that on the rb lol
