niznos »
https://forums.nicoclub.com/niznos-u14767.html
Sun Jun 06, 2004 8:41 am
I just cleaned the MAFS and it seemed to smooth out overall running characteristics.
Also did the Throttle body without removing it. Just sprayed the hell out of it with carb cleaner. There was a ton of black build up on the back side of it, so I drenched the whole inside of the manifold too. Careful, hard to start after that as it is flooded with the very flammable carb cleaner.
Far as I can tell, there isn't much of a need to clean the alt. unless you've got oil leaks and such that would potentially catch fire or insulate the alt. where it would start getting to hot.
You can do any connector that is showing corrosion on the contacts. Not like it would hurt anything.
