MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Sat Jul 27, 2013 10:34 am
Here's some stuff I'd do, assuming you haven't already done these in the recent past:
1: Replace spark plugs
2: Replace air filter
3: Exchange Transmission fluid. If you don't want to pay a shop to do a "flush", you can do periodic drain-and fills (every few hundred miles) 2 or 3 times to get the majority of old fluid replaced with new fluid by only replacing as much as you've drained. Make sure you don't overfill it--only add as much fluid as you drain. Much of the fluid remains in the torque converter, control body passages, and other places, so you can'd drain the full capacity in your driveway. The one thing you CAN'T do without dropping the transmission pan is change the internal fluid filter. This is also worth looking into at 168k miles with unknown history.
4: Shocks/struts. At 168 miles, if yours are original, they most likely need replacement.
5: Any rubber suspension components and joints that are worn (ball joints, bushings, etc.). You can have a shop check these things for you if you're not sure what to look for.
6: Battery. It may still be good, but may need replacement. Most autoparts stores are happy to test it for you (so they can sell you a new one, of course). A battery that's fine in the summer may struggle in the winter, so now's a good time to check on it--before it lets you down in the cold.
Other, non-operational things you could check:
=In-cabin air filter
=Door, trunk, and underhood weather seals. Rubber oxidizes and grows hard with age so it can either crack and fail or lose its ability to form a good seal.
=Make sure your spare tire is in good shape and properly pressurized. Same goes for your four tires in use, of course, but many people overlook the spare until they need it.
If all of these are in need of doing, taking care of them will probably improve the way the car drives the car in a BIG way.
