parting out low compression ca18
sdtouge
Car: 1990 240sx coupe
motors bad *** well as lots of other things so unless someone has a cheap engine, no transmission nothing just motor in good condition im parting this out.
low compression so if you want the motor its in need of a rebuild.things i am keepingclutch370 injectorsturbointercooler and intake piping
think thats about it that ill be swaping over to my ka
also starter is bad if you want it needs a rebuild.
let me know what you want or how much you want for your ca engine.
matt
aim sdtouge
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Well, if you do part it out, I want the water lines for the turbo.
boost_boy
How low is the compression? I think you'd come out better rebuilding it, than buying another engine.
Dee
float_6969
What kind of shape is the head it? Are the lifters making any noise?
slownslurious
how much do you want for the coilpacks? I wouldn't mind having the spares (same for ignitor).
Also dude you are gonna run a stock ca turbo on a ka? let me know how that works out! (15 psi at idle, lol).
sdtouge
i can check everything out next week or so, i need to go pick up the car.
no its a sr t25 but ya still prolly more that 7psi lol
edit, dee i would rebuild it, but i dont know how to rebuild a motor so until i save up more money my car will be out of comision. eventually ill get another ca though and build it up, or i woudl like to.
cuzan0
How much for the motor??? I live 3 1/2 hours north from you if it is a good price i can pick this motor up not this weekend cause it's July 4th weekend but next weekend i could pick it up..
-darrell
sdtouge
i lied. i thought about it and dee is right. i would be a tool to jsut ditch the project. i hate the ka i forgot lol. a rebuild is in order and redoing all my wiring as well.
planing on taking the block and heada to the machine shop to get inspected and replaced etc.then at the leastnew bearingsoil pumpringsmetal haed gasketarp head studsthen replce pistons/valves as needed hopefully some stiff valvesprings etc.
recmonedations would be great.
sorry for the scare* lolmatt
c-rad
Bait and Switch you F.UCKER!
float_6969
Dam.it I need new lifters... I screwed mine up during the rebuild somehow. My head is all noisy now, and they're clicking on startup...
biosehnsucht
try soaking the lifters in some lightweight oil (say 20w) or possibly kerosene for a day or so
if nothing else you should see alot of buildup come out (definately on the kerosene treatment)
just get some of those small bread baking things from walmart (like 2-3"x2-3"x5-6" or so, super cheap) and you can fit about 8 lifters per in there, fill up with lightweight oil of choice and soak.
I did mine both in 20w and in kerosene (forgot what oil) when rebuilding, tons of **** came out.
when putting into head I made sure not to flip them over upside down or anything, just straight from the oil treatment to the head.
azncorruptedo17
Car: 1991 Nissan 240sx SE
c-rad wrote:Bait and Switch you F.UCKER!
lol... thats a classic.
81na ZX
Car: 81 280ZX, 69 Lotus Europa
biosehnsucht wrote:try soaking the lifters in some lightweight oil (say 20w) or possibly kerosene for a day or so
Carb cleaner works good too.
I did that on my DSM's lifter. Then worked them alittle to get the cleaner in all the passages. Made them quiet until I tried installing a remote filter
