J30tChumpCar »
https://forums.nicoclub.com/j30tchumpcar-u152436.html
Mon Aug 10, 2015 9:04 am
Parts still available and I would like to add a more permanent offering of the rest as listed locally on craigslist.
J30 Q45 300ZX Z32 Parts - $7 (WPB)
© craigslist
Modest collection of J30 and 300zx VG30DE engine parts, Q45 body and suspension up for sale
What I have :
J30 doors, faded red $50 each
J30 window regulators $25 ea
J30 engine complete running $250
300ZX engine complete running (non turbo) $300
300zx 8bit chipped ECU Non Turbo (gave me 20hp on the dyno) Fits J30! $175
J30 and 300z intake & exhaust manifolds, timing covers, pans, pulleys and all electrical modules/igniters $10-$25-$75
Z32 engine wire harness (non turbo) $75
300zx turbo short block with bent rod from flood waters, easy fix, no damage to block/crank pistons $300
Larger turbos from this engine still available, $350
J30 NA engine, 25,000 miles on timing belt and OEM nissan waterpump/spark plugs, 2 lb aluminum underdrive crank pulley, 10,000 miles on fresh 40P early JDM turbo heads, JWT S1 cams...worn rings, getting a little blow by running fine when pulled but should be refreshed $650
Good VG30DE heads and complete shortblocks good for rebuilding, none with knock/crankshaft issues $75 each
1994 and 1995 Q45 for parts, there are NO ENGINE PARTS , everything else up for grabs
Suspension
Interior J and Q
Brakes J and Q
Sub frames Q only
etc.
Txt your requests, PLEASE have a reasonable offer
CASH ONLY
