PARTING 95 Q45
93slicktoptt
Car: 93 300zx slicktop tt, 91 240SX COUPE, 95 hardbody slammed daily
IM PARTING OUT MY 95 Q45. MISSING PARTS ALREADY ARE ENGINE,HOOD,DRIVERS FENDER,HEADLIGHTS,DRIVERS CORNER LIGHT,REAR DIFF AND DRIVERS AXLE. OTHER THAN THAT ITS ALL COMPLETE. BODY IS PRETTY STRAIGHT BUT HAS HORRIBLE METALLIC SPRAY JOB ON IT. INTERIOR IN TAN LEATHER WITH HEATED SEATS. FRONT SEAT AND DOOR PANELS ARE PRETTY ROUGH, THE REST OF THE INTERIOR IS PRETTY DECENT JUST DIRTY. LET ME KNOW WHAT YOU NEED AND ILL TAKE PICS . BEST WAY TO CONTACT ME IS BY TEXT OR CALL 5707165410
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
Was the a/c working before you pulled the engine? Did you have to let out any freon when you disconnected the lines? What I need is the low side a/c line that runs from the evaporator to the bottom port on the compressor. It will be the larger of the two lines.
Matt
93slicktoptt
mattd1979 wrote:Was the a/c working before you pulled the engine? Did you have to let out any freon when you disconnected the lines? What I need is the low side a/c line that runs from the evaporator to the bottom port on the compressor. It will be the larger of the two lines.
Matt
Well the motor is actually still in but it's already accounted for, I can test the ac again before I pull it but it worked before so it should still be fine. I'll let you know asap
mattd1979
Alright, thanks.
iliketobounce
Car: 1992 infiniti q45
do you happen to have all four struts and where are you located
SanCarlosQ45
Car: 1994 Q45 144,000
2013 Nissan Xterra Pro-4x
1967 MGB GT Special
Do you have the keyless entry remotes? I would need at least one remote plus the keyless entry computer which is in the trunk above the fuel tank. Its the box to the left of the FPCU, it has a phone line looking cable and another connector going into it. I can give you picture of it if you need it.
93slicktoptt
iliketobounce wrote:do you happen to have all four struts and where are you located
I do have all four complete struts. Middleburg pa
93slicktoptt
SanCarlosQ45 wrote:Do you have the keyless entry remotes? I would need at least one remote plus the keyless entry computer which is in the trunk above the fuel tank. Its the box to the left of the FPCU, it has a phone line looking cable and another connector going into it. I can give you picture of it if you need it.
I have no remotes. But the entry comp might still be in there?
SanCarlosQ45
1967 MGB GT Special
That might work, if you could do me a favor there is an FCC ID number on the label on the computer itself. If the it says either:
A269ZJA073
or
A269ZUA073
I'll take it if it says either of those, otherwise I can't use it. The computer is in the trunk, above the fuel tank, and to the left of the FPCU. It has something that looks like a phone line and another connector going into it. It should just be held in with two 10mm nuts.
93slicktoptt
SanCarlosQ45 wrote:That might work, if you could do me a favor there is an FCC ID number on the label on the computer itself. If the it says either:
A269ZJA073
or
A269ZUA073
Okay I'll take a look asap
mattd1979
Did you get chance to look into the low side a/c line that connects between the evaporator and the compressor? I still need one.
Matt
93slicktoptt
mattd1979 wrote:Did you get chance to look into the low side a/c line that connects between the evaporator and the compressor? I still need one.
Matt
Sorry not yet. The car isn't at my house. I should be able to swing by it today
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
How much for the left-rear speaker and amp assembly shipped to 98024?
Do you have a working CD changer?
93slicktoptt
Lokim wrote:How much for the left-rear speaker and amp assembly shipped to 98024?
CD player no. I have to make sure the speaker sounds okay first.
93slicktoptt
A269ZJA073
or
A269ZUA073
It's A269zua072
93slicktoptt
Matt
I do still have that ac hose. Looks to be leak free
mattd1979
Ok great. PM me what you are asking.
Thanks,
Matt
mattd1979
I sent you back a PM.
Matt
mattd1979
93slicktoptt, Did you get a chance to pull the other line off? I weighed my line at 1lb 9oz. I have a USPS scale. The only difference between your's and mine is that your's has an additional bend on the compressor end of the line. So they should both weigh the same.
Matt
Lokim
Speaker assembly? :gotme
93slicktoptt
Lokim wrote:Speaker assembly? :gotme
Sorry I forgot to reply to you, the rear speakers do not work. As far as the amp working I'm not sure. The front speakers are the only ones working
Lokim
I'd bet the speaker is fine and the amp/wiring is toast. All I need is the actual speaker, my amp is fine. If you can see the speaker and it has no visual damage I'm still interested. Of course I understand you can't guarantee it to work...
mattd1979
93slicktoptt, I hadn't heard anything back since our last chat about the low side a/c line. Is everything ok?
Matt
93slicktoptt
bump it up. I need this thing stripped. let me know before its too late what you need. I have the low a/c line too by the way
mattd1979
I posted stating that I hadn't heard back from you and I ended up buying the low side A/C line from someone else. This was back in October as you can see from my last post.
zarc529
Hey do you have any LCU's? I need one for front right hand side and rr side
93slicktoptt
They have to be there. Are they inside the door?
zarc529
Yeah they're inside the doors the little black boxes lol
