got2b240 »
https://forums.nicoclub.com/got2b240-u18026.html
Fri Dec 10, 2004 11:06 pm
damn, just make sure its got power going to it (brown wire). I asked for a 87 300zx Turbo and I got the Fat type. I just gave them my original with the swap and he matched it up to one labeled 90' Nissan 02 sensor (universal I think) I would definately check your wiring to that. Then check your timing (15 deg) , your tps voltage (.45 v DC at closed throttle), make sure you dont have any boost leaks, because it could be loosing air under higher pressure thus causing a richer condition making it feel really laggy.
-CK
