Partial Electrical Failure
sapix @ RHIT
I have a 1990 Nissan 240sx hatchback. I just replaced the timing chain. tensioner, guides, water pump, and the negative cable for the battery. I put everything back together and got it running after playing with my timing for a few hours. The problem is I don't have brake lights, tail lights, interior lights, the guages don't work, the seatbelt doesn't move, no turn signals or flashers, no wipers, and the headlights won't pop up. The headlights do turn on though, and the car does run. I thought this sounded like a connector I failed to connect or a fuse was blown, so I went through and checked all the regular fuses and looked through my engine bay like 3 or 4 times to try to find lose wires and found nothing. I checked a few of the larger fuses in the under the hood fuse boxes. I think almost all the connections I had off were for the engine, and it is working fine, so I can't figure this out. I did leave my A/C unconnected because I'm waiting for a new idler pulley for that, but that shouldn't have any effect on it. These things all worked fine before I started the project.
Any ideas????
Thanks
NISTECH
check the wires on the positive battery cable make sure they are both connected properly and go through the fuse links again.
