zero.counter »
https://forums.nicoclub.com/zero-counter-u11169.html
Mon Mar 14, 2005 3:12 pm
I have an 89 ka24e which was in pieces when I purchased it and I have some serious questions if you could answer them.
1. I am in need of the heater and vacuum hose routings, to say the least. I have all of the heater hoses and about 6ft of vacuum tubing purchased from autozone, and have only managed to get some hooked up. I have already consulted the FSM and the Haynes/Chilton, which only show diagrams. A good pic is or would be definately helpful! Pics would be awesome, and I mean very good close-ups of the locations.
2. I also need to know what the where the orientation of the inline temp sensor is supposed to be. Top or bottom inlet/outlets of the block.
3. I am also not sure if the car I have was supposed to have the Intake Air Temp sensor, since I cannot find the lead that is supposed to be coming off of the MAF plug and was wondering if anyone has a NON-IAT KA24E. I do know that some models of the KA24E had one built after a later month in 89, then desisted in the S13 KA24DE.
4. Where does the PCV valve hose route to from the PCV. I am in the process of looking up a part number for the hose as well.
5. I have 2 extra harnesses coming off of the O2 wire in the rear of the head and cannot find a place to plug in. I have already removed the EGR and fabricated a block off plate.
6. I have one loose sensor hanging on the passenger side under the oil filter (not the oil sensor), which I cannot find a home for.
7. The big one besides the heater hoses is the FPR on the fuel rail with the connections to the device on the back of the head with some more vacuum line connections.
History: The guy before me replaced the head due to bent valves, but left the car in complete dismay besides replacing the head. He just threw all of the hoses in a box and sold the car for $75 due to time constraints. I have already replaced the injectors with O-Rings, O2 sensor, radiator, etc...
I am also in need of the fuse cover for the fuse box right underneath the factory airbox.
Thanks ahead...
I AM WILLING TO COMPENSATE FOR VERY GOOD PICS OF THE NEEDED LOCATIONS
