Part Throttle Stutter
WDRacing
Anyone running the SAFCII with a 300ZX MAF have problems with the part throttle cruise. If I try to maintain a speed without accelerating the motor stutters pretty bad. Runs like a raped ape with the throttle stabbed though.
My settings are ALL CORRECT and the AFR is tuned via wideband for 14.5 off boost and 11.7 on boost. So it's not a matter of tuning.
Any suggestions for me to check?
WD
NateDogg
What does the timing show when this occurs and at what load/rpm/tp?
WDRacing
RPM varies a tad, usually 2400-2800. It is almost always with 17-21% throttle though. And only when that position is maintained.
Timing is only controlled via the stock ecu while off boost. I have the BTM to retard timing on boost.
NateDogg
Maybe S-AFC is throwing off the timing. How do your plugs look? Maybe 14.5 is a little lean?
Craving4Boost
Car: 91 240sx fastback
WD, how partial are you talking about? with a piggy back it does not like partial throttle and you can get weird things happening...but how bad is it? it could probably just be the fact you have a piggy back
virus77
Car: 95 S14, 71 240z, 97 e320
whats your A/F when the sputtering is happening?
toki
where are you hi/lo crossover points? im going to guess you are dipping in to a map that is too rich.
WDRacing
AF is 14.7 - 15, the throttle positions aren't close to my hi/lo points. I'm in turbo lag until 4200rpm so mine are set to 35-60. I'm going to hook up my multi meter and check my TPS voltage today. I may have bumped it during the down time.
WD
klattr1
Car: GT42R powered S14/KA
is the bov opening/closing during that stu stu stu studder?
whats your vacuum at when it does it as well?
nissanfanatic
Car: 1992 Nissan 240sx SE
I noticed the exact same thing with my stock ECU w/FMU and BTM setup. I would stutter really bad going right into third gear. After doing the Enthalpy setup, I noticed it went away. But I remember Ivan saying something about Phils car doing a similar act adn it was the TPS. Not that it wasn't set right, but that it was just bad.
WDRacing
Car just crapped a starter. More info to come in 8-9 friggin days.
