It's a very peculiar problem. If you start the car when it's cold, it will do its usual crappy idle until warm, then if you don't drive it, it will sit and stay idling. But as soon as you drive it and the miss starts, it won't idle at all, you have to keep about 5-10% throttle just to barely keep it running. Actually, it feels more like fuel blowing out the spark, it's not a very clean miss, you know, it's not a complete miss that makes it sound like a subaru. However, i've gone from 53% to 38% fuel correction on the FC with no clearing of the miss, so i don't believe it's purely a fueling problem. So, i was wondering if anyone has any fresh ideas as to what the problem can be cause we've been trying all week and haven't solved a damn thing. Here's what we've tried so far:
-Cleaned + gapped plugs.-Installed new plugs, 7's instead of 6's.-Swapped coilpacks-Installed a genuine TT Z32 maf.-Swapped ignition subharnesses.-Reset TPS voltage-Swapped throttle bodies and TPS's.-Swapped from power FC to JWT and back again.-Pressure tested the intake, no leaks.-Removed Nismo FPR, installed stock FPR.-Resealed Nismo FPR, reinstalled, base FP set to 43 psi.-Checked entire fuel system for blockages, leaks, etc.-Messed wildly with FC fuel corrections.-Reset base timing.-General debauchery under the hood.
Anyone have any new ideas?!? At this point I just want to buy a new wire harness and pull the engine and start from scratch.
