DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sat Jun 06, 2015 11:01 am
You will have issues possibly with the front end of the exhaust because of the DP's for the turbos, not sure as I myself have not wrenched that area, but there's that obvious difference with the DP's. The rest should be the same shape and therefore fit, although it may also be possible the exhaust tubing diameters are different due to the differing output of the engines, and fact Nissan early on was not set in all areas such as the brakes and elsewhere.
The suspension also should technically fit, but there are some differences with the sway bar diameter and brake sizing (26mm on pre-'91 NA's) so this would not be considered an equal swap if swapping ALL parts.
