Part request / cross-ref request
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
R33 RB25. Water-pump bolts. The small bolts on the PULLEY side, not the ones that mount the pump to the block.
I used eh?'s FAST diagram http://www.rbforums.org/water.html but it does not list them. It is located directly in the center of the page, below the bolt listed as '0811-0501A'
These are the same four small double-ended bolts & nuts that come with a new pump.
I _REALLY_ find it hard to believe that I would have to buy a new pump to get the bolts, but lets just say that I would not be 'shocked'...
Is there any other engine that I could use to cross-reference it with?
240z4u
Car: '95 Nissan 240SX
I may be missing your question altogether.. are you wanting the bolts that attach the pulley to the front of the pump?
I went to ace hardware and grabbed some M6 bolts/washers and called it a day.
Evan
l0nestar
2004 Toyota Altezza
Hey! your back!
Yes. The bolts that attach the pulley to the front of the pump.
I was wanting to avoid using all-thread, but I guess using some small bolts would work too! Silly me thinking of the OEM methods..
I'll stop by Ace or Lowes tomorrow and look into using regular bolts, since I'm not using a clutch-fan setup. I forgot to take one with me.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
The bolts that attach the pulley to the pump aren't really bolts. They're basically all-thread with an unthreaded section so you can tighten the pulley nuts down without them spinning.
eh?
It is there, just a bit further down. look at the 08226-61410, that's it I think.
Here's a link, crosses to a Z32 studhttp://www.courtesyparts.com/0....html
imotion s14
Car: 1997 240SX
l0nestar wrote:R33 RB25. Water-pump bolts. The small bolts on the PULLEY side, not the ones that mount the pump to the block.
it's below it near the bottom.
08226-61610
i got a set, brand new. $5 shipped. I'll cross ship them to you to save some time, just give me your address.
[email protected]
l0nestar
2004 Toyota Altezza
Just replied via email. Thanks a lot man!
imotion s14 wrote:it's below it near the bottom.
08226-61610
[email protected]
