part of spark plug wire boot stuck in spark plug
goj_cloud
i just fixed a recent problem with my car and i needed to change the spark plugs to make it perfect. when i went to pull the spark plug boots they all came out except one. now the bottom part of the rubber boot is stuck in the spark plug, and it looks impossible to get out normally. how can i get myself out of this one
see the part that got stuck in the hole
Modified by goj_cloud at 11:58 AM 1/5/2010
NizzmoS13
Car: 240sx
Same exact thing happened to me, I just used a long pair of needle nose pliers to get them out, it was a tight squeeze but they worked.
goj_cloud
that might work , i dunno heres a more detailed pic of what the problem is i found onlinehttp://forum.ih8mud.com/80-ser...98373
Modified by goj_cloud at 1:03 PM 1/5/2010
NizzmoS13
Car: 240sx
Yes I had the same thing with the rubber end stuck to the spark plug, also I forgot to mention the most important part, in order to get the long pair of needle nose pliers close enough I took the valve cover off and it wasn't a problem to get it out after that.
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
I always use my long pick tool and grab it. A screwdriver will work. Brainless to figure out.
johntom
Car: 1991 240sx fastback
wow bro same thing happned 2 me 2 days ago, i got sum pentration fluid down there, let that sit over night then went like a mad man on it stabbing it with a screw driver, then took my air nozzle at 200 psi with a rag over the hole 2 catch the fluid first, then blew the litle ruber peices out, man that was fun!, then use some eletric grease on these plugs so it dont happen again
a simple spark plug change can never be easy on a high mileage 240lol
benz88
Car: 91 240sx
this just happend to me too. WTF this seems like a normal thing haha./
j240sxxx
Car: 95 240sx w/kouki conversion
use two flate head screw drivers .. Thats what I did.
Idahos13
Car: 93 240sx hatchback
I used a piece of metal like a paper clip, but slightlythicker. And I also used needle nose pliars, like said above.Hope you get it man! It's not that hard just keep trying you will get it!
LingeringSuicide
Car: 1990 240SX hatchback 1993 240sx Vert
or if you really want to over think it if you dont have a set of picks take the valve cover off and use needle nose pliers...
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
did this really require a thread?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Im with him ^
