part number request
dhen
Car: MGA w/ CA18DET
OK, so I have a very large leak at the back of my transmission. It's a JDM 5-speed. What kind of car should I say I have to get the seal? Is it the same as a 1990 240SX?
BTW, is there any unwritten trick to replacing this seal? I have the manual, but I've never done it before.
Thanks,
Darian
MaximA32
Car: '98 Maxima (RIP)
'04 Maxima - Traded
'06 Mazda 6S- Traded
'15 Altima
At the back of the transmission? Are you referring to the output shaft seal? Post up a picture of what you're looking at to help us figure out how best to help.
dhen
Car: MGA w/ CA18DET
Yes, you are correct. Where the driveshaft goes into the transmission. I think I damaged it when I put the driveshaft in because it's leaking like a sieve...
TheMAN
should be the same as the 240SX ones
I know the dust sleeve is different but it's not something to worry about
dhen
Car: MGA w/ CA18DET
The dust sleeve just pops out, correct?
float_6969
It's the same as the 240sx.
Dust sleeve is just pressed in there lightly, so tap it out with a flatblade and a hammer.
I have never seen one leak though, are you sure you don't have too much fluid in there?
dhen
Car: MGA w/ CA18DET
I'm not sure because it's impossible for me to check with my setup. It leaks as fast as I fill it, though.
cbh148
Car: 2000 Civic Si, 1993 240sx Hatch CA18
I'm not sure if my rear transmission seal is leaking, but I always do see a drop of gear oil waiting to fall off that little rectangular part that's sticking out of the bottom of the rear of the transmission.
I haven't really investigated it much because my transmission started feeling like it was hard to shift, so I went ahead and changed the gear oil, expecting it to be low since I saw the leak. however, it had a lot of oil still in it, and didnt seem to feel a whole lot better when I put fresh 75w90 in it (maybe a little better).
I don't think I put any kind of RTV or gasket under my B&M shifter. Dunno if that would cause much of a leak.
let me know how it goes if/when you change out your rear trans seal. good luck!
dhen
Car: MGA w/ CA18DET
A drop or two I can live with, but this isn't holding oil at all. Like I said, I think I damaged it when I installed the driveshaft.
