Part names or numbers for 2008 M35
AdiGri
Car: Infiniti M35 2008, Base Sedan, Platinum Graphite
Hi folks,
I recently got a 2008 M35 (that was fixed after a front collision). Whoever fixed it, left a few things undone and I would like to take care of those. I 'm trying to get some replacement parts and I'm not sure where to find them. I tried different diagram sites but I cannot find them:
- A/T gear position switch - I am assuming that there are different parts for the face plate and the switch itself. I'm looking for the switch because I have the A T Check light coming on and off, randomly and I'm assuming that it's either bad wiring or the switch itself is busted. The mechanic said that the tests indicate a problem with the switch module.
- Engine cover - Not for the engine itself, but the one that covers the right side of the engine compartment (when you lift the hood).
- Cap for the coolant reservoir
Please note that I'm living on an island with no Nissan/Infiniti dealears/service shops to go :(
Ilya
Welcome to the site.
I did a quick search and had trouble myself, but if calls to the US (or whatever country you choose) are't terribly expensive you could also called an Infiniti dealer and speak to the parts guys. Usually, especially if you're from out of town (they can't lose the sale), they are willing to give you the part numbers, etc.
AdiGri
That's a good idea, I'll lookup some dealers in Florida, maybe they can help and even ship some parts.
tbright
Car: 2007 m35
I see the center cover and the radiator cover here but not the 2 side pieces:
https://discountinfinitiparts.com/parts ... am=viewAll
BTW the cap for the coolant is attached to the cover on the passenger side.
tbright
Car: 2007 m35
Part No. for the cover is P675-5721-200. I saw one on eBay but the listing has ended.
tbright wrote:I see the center cover and the radiator cover here but not the 2 side pieces:
BTW the cap for the coolant* is attached to the cover on the passenger side.
*Edit: Cap for the windshield washer fluid.
AdiGri
Thank you! Using the cover part number that you mentioned I narrowed down the actual cover. It is actually 66825-EG000, called COVER-STRUT,LH. When I mentioned "right side" I've actually meant as you were looking at. It is officially the "left side" (the driver side), sorry for the confusion. I found the listing on http://www.infinitipartsdeal.com.
In the mean time, I found the parts for the A/T gear position switch as well, listed under the Power Train / Auto Transmission Control Device section (there are several).
:dblthumb:
